When I bought my 92 GL three weeks ago I knew it was overheating. There was also oil in the water but no water in the oil. No white (or any other color for that matter) smoke coming from the tail pipe.
The first day I removed the valve cover and re-torqued the head bolts. I also removed the radiator and flushed the cooling system. There was no thermostat in place and I left it that way.
After that, no more oil in the water, and still no water in the oil. It even passed the smog check (I'm in California). However, it is still overheating.
When I removed the radiator, it seems to be fairly clogged. Y tried to flush it as much as I could but I'm guessing there are tons of deposits in the inner vertical tubes.
The other thing could be the water pump, but it's not leaking or making funny sounds.
The electrical fan comes on and stays on since the temperature doesn't seem to go down once it starts rising. Freeway speeds seem to agravate it even more. I thought that air flow at 60+ mph would help keep the temerature down. Any ideas? I'm thinking about replacing the radiator first and go from there.
I want to swap the engine with a B8 as soon as possible but I also want to keep driving it in the meantime.
