I have a 91 festy and I just cleaned the motor today to find an oil leak. Well it appears to coming from the bottom, Oil pan or maybe crank seal. So i took of the two bolts that hold on the timing cover on top and looked and felt the timing belt and there was no signs of oil. I was told and read that if the crank seal was leaking then there would be oil residue in and on the timing belt and cover is this true. If this is true can anyone give me some insight on how hard it is to replace the oil pan gasket. Also how the heel do you take of the rear drums to adjust the e brake. There is no access to get to the little adjuster thingy on the back plate. Any help would be great for both these issues. Thanks
