:help::help::help::help::help:I live in jeff county missouri and was wondering if there is anyone around that area that knows alot about festys that could help me do some of the work need to my daughters car. It needs I think at least either the oil pan gasket or crank seal replaced, but I just figured if Im going to go that far I would do all the seals and the water pump and timing belt. Ill get the parts some drink and snacks and we can go to town. So if there is anyone out there in Ford Festiva World that has done this before that could help me and or be willing to help me that would be great and my daughter would be happy her car isnt leaving its mark every where. Just let me know send me a message a we can go from there. Thanks TAYTAYS dad Mark:help:
Need help in Missouri with repairs
There are quite a few members around that area with the skills. Maybe they'll chime in tommorrow morning.---------------------------------------------------
How about doing an oil change and dumping in a bottle of seal conditioner, for starters. Clean off the motor with Simple Green or Foamy Engine Brite. Then see how the leaks are. But do a valve cover gasket anyway--easy to do, you don't need help with that (perhaps with a little advice from here, IDK your level of mechanical ability).
Definitely get the Haynes manual if you don't have it. Should be readily available at one of the McParts stores around you.
Edit: just noticed you had the thread "Oil leak on 91 Festy", so much of this advice is old news to you.Last edited by TominMO; 09-27-2009, 08:22 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks FestivaWES, what i have found is these cars are more popular than i thought and they are addicting. I want to get another one for me to fix up, hell i thought about taking my daughters festy and giving her my 07 ram. ............Well maybe not, but I would like another one.Lifes to short to sweet the small stuff. Enjoy everyday like it was the last.:p
Originally posted by taytay91 View PostDoes that seal condition really work? I did clean the motor this weekend and the leaks are around the crank/ oil pan area. I plan on replacing the v/c gasket.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Questions concerning the oil pan gasket for more experienced members:
Is this gasket sealed on with silicon, such that it should be left alone if original? Or should he go for it on general principles?
Also, is it simply a matter of undoing the oil pan bolts (I'm guessing around 18 of 'em), and then dropping the pan, or is it more complicated than that?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by taytay91 View PostWhat is the brand name and where can I get it.Last edited by TominMO; 09-27-2009, 08:34 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You know Tominmo i have seen that before but was hessitaint to get it, but if you say it could work its definalty worth a try, and since we have a self oil changing car after a day or so i should be able to add it without changing the oil again. NOTE: I changed the oil this weekend.Lifes to short to sweet the small stuff. Enjoy everyday like it was the last.:p
Self-oil-changing! :-) I like it! Sez on the bottle it takes about 250 miles to fully work. (You might need two bottles! If so, add the second one 125 miles after the first.)Last edited by TominMO; 09-27-2009, 08:49 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I usta have an old Datsun pickup that used a quart of oil every 200 miles; but it was leaking out the valves or maybe the oil-control rings, so stop leak didn't help that vehicle. But it has worked well on several others I have had. The Datsun ran great tho. Made two DC to St. Louis trips with it, stopping every 200 miles to add the oil. It was an old super-rusty beater truck and not worth the expense of repairing this problem.Last edited by TominMO; 09-27-2009, 08:53 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
OK Ill give it a try. Now I had a toyota one time and the previous owner used bars stop leak for the radiator and it clogged up the radiator and the heater core. Now I know this is different but have you seen any negitive affects for using this?Lifes to short to sweet the small stuff. Enjoy everyday like it was the last.:p
Originally posted by taytay91 View PostOK Ill give it a try. Now I had a toyota one time and the previous owner used bars stop leak for the radiator and it clogged up the radiator and the heater core. Now I know this is different but have you seen any negitive affects for using this?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Where is House Springs ?sigpic
