Broken Festie...HELP lol
  • #16
    Originally posted by MONSOON View Post
    Didnt snap a timing belt did you?
    I"m the winner!
    Maybe over tightened the tensioner?
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
    • #17
      Don't buy the cheap belt.....go with the gates and not too tight.
      -Greg
      Redneck Engineer
      FOTY - '09
      • #18
        Not the problem I'm sure, but while you're in there, I hear the water pump is exposed.
        • #19
          3 fusible links are on the driver's side shock tower, in a little black box a few inches below the top of the tower, as you're standing at the right front of the car. They look like 3 little red loops of wire. If you pull them out to check them with an ohmmeter, pull very carefully as not to break them. 20 year old wire tends to get brittle.
          Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
          In memory of Dean Allen - V8 Festiva 1955-2010
          • #20
            Correct!! And as we learned in Shane's parking lot, they can be a little iffy at times. Already exchanged mine for the three that Festyboy gave me. Thanks again.
            To the OP, your first post said that you jumped it to take it to the store. Has it been sitting a while? I'm kind of seconding the notion of making sure there's not too much tension on the belt, and definitely don't go in and grab the cheapest one they have. It's cheap for a reason.
            1988 L - 232K miles Batstiva
            1989 L - 247K miles Slick
