I just bought a 98 KIA Pride GTX with an automatic transmission. The engine is the original carbureted 8-valve SOHC B3 with approximately 180k kilometers (about 113k miles). Only parts loading the engine beside the tranny are the alternator of course, and the A/C compressor (IOW no power steering).
The previous owner knew nothing about automotive maintenance. All he did was put gas in it and drive. So basically, the poor thing has been completely neglected for years.
Here's what I've done so far: (as of September 25, 2009)
* Flushed engine with 3 litres of SAE 40 oil and .5 litres of flushing oil
* Replaced oil filter and filled with Castrol Magnatec 10w-40
* Flushed cooling system with Prestone Super Radiator Flush
* Filled cooling system with Prestone Antifreeze/Coolant
* Replaced fuel filter
* Filled tank with 93 RON (AKI 87 back home) unleaded gasoline and a bottle of STP Fuel Injector and Carburetor Treatment
* Adjusted distributer timing
* Adjusted both Throttle Idle Speed and Fast Idle Speed
* Replaced timing belt and tensioner bearing
* Replaced both alternator belt and A/C compressor belt
* Replaced accelerator shaft, CV joints, tie rods, and rack & pinion
* Replaced engine and transmission mounts
The symptoms that it's exhibiting are just as in the title. After topping off the oil and running about 600km, I had to add another 200ml. Also, it's only getting about 7-8 km/l (about 18 mpg). Now keep in mind that most driving here stays between 40-80 kph (25-50 mph) when there's no traffic. This holds true for about 80% of my driving here; the other 20% is bumper to bumper moving about a car's length every 30 seconds. Brand new, the car is supposed to be getting about 12-13 km/l (about 30 mpg) in these driving conditions. So I was expecting about 10-11 km/l (about 25 mpg).
Found that the automatic choke was stuck, so opened it permanently (cold starts are definitely not an issue here in the Philippines), but it still runs way too rich. Adjusted the air:fuel mixture as lean as possible, and advanced the timing as much as possible while keeping the idle smooth around 950rpm, but still running way too rich.
I thought my compression might be low due to worn rings, which would also explain the oil from the breather. However, if I was getting blowby due to worn rings, wouldn't my plugs be oil-fouled (wet-fouled) instead of carbon-fouled (dry-fouled)? I'll have a compression test done tomorrow to see if it might be the rings, and I'll try hitting the carb with some cleaner to see if it clears anything up.
BTW, I already checked my PCV valve, and it's still good. I also consulted a Bosch certified mechanic here to see if changing the rings would be my solution for the blowby. He told me the blowby is a common illness of Prides/Festivas. He said that changing the rings would eliminate the blowby for about a year, then I would experience oil from the breather again. How much truth is there to this?
Any relevant information and advice would be greatly appreciated.
:newb:
:newb:
