I have a 93 Fesity L
I want a tach, i like the look of the white guage, and i want accurate milage displayed.
1) Need a writeup for the swap
2) Is there a way to turn the mileage back without breaking anything?
3) Will all the wire be there for it to work properly?
4) My current cluster is very dim at night, is there a way to fix that(and yes i turned the dimmer all the way up)
thanks yall
thanks yall
I have been asking on and off for a couple of years now, and everyone seems to drop it around the time I would get that answer. From the manual's diagrams, they make it look like the pins would have to be rotated in order around the connector to be in the proper position. Add that to a bad experience with what I can now determine was a bad cluster assembly, and it had me gun-shy to try a second one!
... Just messing with you... It should be fine.
