Where is my Leak?
  • #16
    Originally posted by brickdog2000 View Post
    Did you fix the leak? i am wondering cause I have the same problem. I think it is my oil pan, but I have replaced it 3 times and said screw it. Now it is really starting to bother me cause its makes my driveway look like poop to say the least. With mine though it sprays it all down the undercarriage of the car too. Any advice you have will be greatly be appreciated.
    I have not fixed it yet, but it's funny you bring this back up, because my dad will be off work for 10 days for Christmas soon, and we should be looking at it then, along with my trans leak, brakes, and switching my gas tank.
    • #17
      Is your transmission leaking where the cv axle goes into the tranny? If so then it will be the seal, I just replaced mine. The part is around 6 bucks at auto zone. The only hard part for you might be removing the old seal. I use a slide hammer that I have with a attachment on the end that looks like the end of a small pry bar. That tool works like a charm. Or it could possibly be the o-ring for your speedo cable.
      Man should eat when he can for Man does not know when his last meal will be.
      • #18
        I would guess it's leaking from the oil pan gasket. When the engine is running, the pistons pumps the air (in the crankcase) which would cause the oily-air to blow out, not drip.
        Assuming:It is oil, not anti-freeze. Both are oily.
        • #19
          Have you fixed your festy yet?? im having the same problems!!!
          • #20
            the responses in this thread are making my eyes bleed. Please just listen to post #5. replacing that involves doing the front main and oil pan in the process. and make sure the o-ring on the dipstick tube is in place.
            • #21
              I just pressured washed my engine so hopefully I will find out soon.
              • #22
                tell me where on the engine it comming from ( I cant see the pictures)
                I would not rule out the distributer seal. just run your finger under there and see if it is wet. it will be clean oil.
                I think the oil pressure sender is on the backside behind/under the alternator?
