park lights permanently on
  • park lights permanently on
    park lights are permanently on with even with key out of ignition and lights off. removed room fuse so battery dont go flat. this is a 92 GL festiva. is this a relay issue ?
    Drivers side, underhood, behind headlight. You can get one for a 91 - 96 Escort its the same thing except for little tab that needs to be broke of for it to fit correctly.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      I belive the parking lamp relay is on the passanger side behind the air box
      92 GL - parts car
      97 aspire - parts car
      87 323 DX - daily driver
        the car doesnt have an air box, non-efi model. hope this is whats faulty. thank you
          monsoon is correct, it's behind the driver headlamp. i just messed with one on chills car at FM3. check to make sure you don't have a constant ground signal to the relay (the column switch is a ground side switch), if so, you've rubbed through on the main harness behind the driver fender and have a short to ground causing the lamps to be on all the time.
            No location so we assume in USA.
            In US '92 Festiva GL = EFI = Airbox.
            Unless it was swapped for a carbie or you are not in the US.
            Please add details, better yet add a location to your profile.
              hmm
              found rely behind the passenger headlight, it was for the cooling fan I couldnt find a rely for the lights except the main one for the headlights, the park lights remained on when I unplugged the main relay.
              found a blue wire under the dash that turned them off but it also turned the dash, stereo, and heater off as well, any ideas out there? Thanks we are in New Zealand and it has a carburettor
                Better permanently on then permanently off! lol
                BTW, Thanks again Festyboy.
                Steve GT
                  yea permanently on means flat battery then fng, that aint good.lol
                    Yeah, but you can always disconnect a fuse or the battery itself.
                    If you can't turn them on, you are a road hazard and could get a ticket.
                    Steve GT
                      fng,= ford no go wont be going no where if the battery goes flat lol so technically car in garage wont be a road hazard much lol. yea but I know what you mean we have been taking the fuse in and out when need be, would rather just fix the situation and keep the wife happy
                        you might need to instill the help of FestyMic (Aus) as he may be able to help with the differance in wiring between the silly american and Kiwi versions.
                          solved, there is differing wiring colours for whatever version festiva, can cause week of lost sleep over simple radio.
