Hi All!
I have a Festiva '89 (2bbl, 4gear manual, L model. last year I posted another engine question). The issue with the engine is this: when driving uphill (e.g. a gradual 6% grade), it decelerates gradually if I am driving with a good initial speed before hitting the hill (e.g. say at 50mph, it goes down to 25-30mph), it is even worse over sharp inclines with initial low speed (10-20mph -> 5mph). It is worse yet, when starting at the bottom of a hill say with 30 deg incline, it does not want to go!!
The story is long as how it ended up like this, but a tuneup expert tuned up the engine performance (the carb, the knobs for engine rpm, etc, NOT changing spark plugs or oil) when it was way out of tune, but basically he did not check for engine power when a hill is hit (note I have foot on the pedal close to the floor even when it is decelerating!). When car clears the hill (say the road becomes flat or downhill), then it accelerates and regains its speed.
I need to know what some of the causes of this situation may be (I guess it is throttling somehow, but if so, why?). Any suggestions, ideas or questions that may solve this mystery and how to go about fixing it are most appreciated. I will check responses here.
Thanks!
Joe
Thanks!
Joe
