Need help finding 2 things on my 1990 festy
  • Need help finding 2 things on my 1990 festy
    can some on do a "hoods up" picture for me as to where the :
    1) horn is supposed to be mounted
    and
    2) The OBD-I box is supposed to be at
    Also how do you drop the gas tank info would be appreciated (possible leak)
    and
    Idle adjustment
    well thats all
    Joe
    :sign3:
    thanx in advance
    Go Ahead and Laugh .....Mines faster,more fuel efficient, ...AND PAID FOR!!!!!
    :sign3:
    Hey...Thats my EMOTICON!!!! Ha ha!
    Is yours not dropping to low idle speed at warmup? Mine's staying at high idle.
    Dan
      Joe.....we need to know carb or efi?
      -Greg
      Redneck Engineer
      FOTY - '09
        EFI for 100 alex
        I'll take EFI for 100 alex
        LOL
        Its an efi
        Joe
        :sign3:
          Weeeeeeeeeeeeeeeee??????
          WE? that solves it ....You do have a hampster in your shirt pocket dont you euro???
          Joe
          :sign3:
            Horn is mounted in front of the front passenger wheel well, behind a cover. Lotsa peeps relocate it to the engine bay so it won't get dirty.
              ECM is under dash, left side corner on firewall. idle adjustment is a rubber cap on the throtle body: remove cap, take #2 flat tipped driver and rotate screw to desired idle. (do this with engine warm)
                dropping the gas tank is a pain in the butt, not to hard just time consuming, start by lifting up the rear cargo rug and removing the plate covering the fuel sending unit, disconnect the 2 fuel lines at the sending unit and undo the 8 or so screws holding the sending unit on, put the sending unit and gasket off to the side.
                remove the other metal plate underneath the backseat and proceed to remove the fillter tube neck and 5 or so fuel hoses attached in the area, (there is one hidden on the underside). proceed to jack up your car and remove the 4 bolts holding the tank on and the one bolt holding the e-brake line in place.
                I found it easiest to remove the gas tank lying underneath the drivers side and pulling it out, and then fiddling with it until it falls down making sure to not hit the nearby fuel line.
                probably wanna remove the drain bolt on the tank before you do this =P
                  Just a little more clarity Joe....if you lay on your back and slide your head under the bumper on the passenger side....it is up inside the cavity behind the bumper between the tire and bumper.
                  Tom....not sure how you can relocate the horn unless you knew where it was at....then you would have to forget where it is at....and then rediscover where it is at.
                    huh?
                    sorry, the horn is located behind the bumper below the passenger side head light
                    with the option of having a second one behind the bumper below the drivers side head light(yes, there is a wire there, just like the passenger side)
                    I am the original
                      You and I described its location in different ways, but it's the same location; if you look in the passenger wheel well, at the front is where the horn is--behind a metal body-colored cover, to protect it from road debris. You can't see it unless you remove the cover, or look from underneath. Or as you described it; same location. I suppose you could see it looking down into the engine bay; but I found it the other way. Also, I suspect it's easier to get at it from below.
                        Oh very funny. You know perfectly well what I meant.
                          thank you all!!!!!!!
                          Thanks tom, geneva, and mechanicaldj,and all others
                          This is what makes a GOOD board a GREAT BOARD :cheers:
                          Joe
                          :sign3:
                            Sorry...not sure what you mean...was relocating my horn....LOL:laughing4:
                              Hi Joe I'm from New Zealand and I gave up trying to find the horn, I mounted a brand new one in the engine bay, check to see if the horn fuse has blown, if it has disconnect the horn relay and check its working OK and it most probably will be, cut the wire in the engine bay to the horn and replace the fuse, if the fuse is now OK get a new horn they only cost a few dollars and hook it in then you are underway....and its Toot, Toot, Toot. :p:p:p
                              "all I ask is the chance to prove that money won't make me happy":simon:
