Hey guys!
I have been searching for a few days and haven't been able to find a solution to my problems. This car has been sitting for 5years. I changed the fluids, seafomed the engine, and replaced the sparkplugs. The car will start and immediately idle at 1500-2000rpm, idle adjustment screw is no help. To make things worse the car will not rev above 3000rpm, I had the air cleaner top off and noticed fuel spraying out the carb when the accel pedal was floored and the engine bogged at 4000rpm.
Vac. readings are 10-12, I unplugged the single wire connector and upper vac. hose to check timing as per hood decal but the dist didn't have enough adjustment so I couldn't set timing to 1deg, is this an indication timing belt slippage or am I disconnecting the wrong wires/hoses? I was unable to check DTC's at the time (couldn't remember the jumper settings
) and it will be a few days before I can get back out there to mess with it, hoping somebody might know what to look for.
Any info greatly appreciated!
-Curt
-Curt
