Timing without sti connector
  • Timing without sti connector
    Does anyone know that if I time the ignition timing with a timing light but I don't have the sti connector or so I think. Can I time it without the sti? What are the effects when grounding the sti? Does it advance the timing a little when the sti is grounded?
    Any help please?
    Thanks
    :festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
    Can someone please see on his engine the timing, without grounding the sti connector using a timing light and tell me what the timing is at idle. I know that the correct timing is 10 degrees btdc with the sti grounded but I want to know what will the timing be without grounding the sti connector.
      It will stay moving as the computer tries to keep it at the "perfect" spot.
      -Greg
      Redneck Engineer
      FOTY - '09
        If the computer tries to make it at the perfect spot at idle, why is the distributor adjustable?
          For what they call "base" timing. All motors are a little different......altitude, temp, grade of gas, etc.....
          -Greg
          Redneck Engineer
          FOTY - '09
