Surge under acceleration
  • Surge under acceleration
    I also was wondering if anyone has had a surging issue while under acceleration, my 93 festiva has done this since i got it 2 years ago, normal or not, what might cause this :help:
    more info please... and a location in case there's someone near by that can lend a hand.
      I'm in north Missouri, when under acceleration going up through the gears i can hold the gas peddle at one spot but the power comes and goes like feathering the throttle
        What have you replaced? Have you done a tune up on it? If so, what else did you replace besides the obvious(plugs,wires,cap and rotor)?
        - Unknown
        - Quentin Crisp
        - Bumper Sticker
          possibly a dirty TPS?
            haven't replaced anything but plugs and wires, doesn't act like a throttle position sensor, almost like a fluctuation in fuel pressure (haven't checked that yet) what kind of pressure should a 93 with a 1.3 run?
              may want to pull the engine codes
              even if the check engine light is off
              I am the original
                check engine light has been coming on every so often for about a year now but goes right back off, guess i will run a check and see what it says. thanks guys
                  Plugged fuel filter. Dirty injectors. Bad cap and rotor.
                  - Unknown
                  - Quentin Crisp
                  - Bumper Sticker
                    One of mine did that. It was blowing a lot of oil out the valve cover hose and running it through the engine. I figured it was fouling the Oxygen sensor. I plugged the intake pipe and ran a long hose down under the engine so the oil vapor goes on the road instead of in the engine.
                    It fixed the surging. Rings or engine change comes later.
