Ok, just to set things straight, we're dealing with a 89 carb here imported from japan... so I'm not sure if things will be different..
So first question.. how do you set the idle? The picture in the haynes manual is completely different from what the carb looks like
Second question... what kind of filter dose an 89 carb B3 take? I picked up a festy one and it didn't fit... I had a B6 one kicking around and it worked.. is this right?
