VALVES DONE, NOW ABOUT THAT HEATER....
  • VALVES DONE, NOW ABOUT THAT HEATER....
    Did the valve adjustment, in fact I think I did all 10 12,000 mile interval adjustments from how loose they were.
    Gonna work on the "heater" today- wish me luck.
    I let you all know if I make any earth shattering breakthroughs..... :roll:
    Good luck!
    That reminds me - I gotta do my valves, too!
    Let us know if you make any life-altering discoveries...
    Regards,
    Tim
    White '89L auto - Sold!
    Silver '06 Rav4, 95k!
      Here's what I found with the heater....the flaps that "shut off" part of the heat going to the floor were not closing much and the gaskets on those were whooped. I adjusted the cable and lubed the whole works and I used some black duct tape to "adjust" the holes for the floor.
      Also, the cable that moves the flap to mix the "hot" air with the cold was not adjusted. I adjusted it and the door closed all the way so no cold is mixed in.
      I got tons of air to the defroster, now I'll need a cold day to see if the heat is any better. (tomorrow morning).
      BTW- what a difference the valves made! They were making so much noise, the whole ride quieted down afterward. They were LOOSE! (ABOUT A QUARTER TURN OR MORE).
