Anyone identify these new parts,bearings , seals...
  • Anyone identify these new parts,bearings , seals...
    Before I go buy anymore new,I would like to see what these are ...Anyone ?
    I don't know but it may help if you put something next to them to help the viewer estimate the size (like a dime). Have you googled those part numbers?
    Oscar
      I have put them on and it will say things like "Bearing",but,not what bearing.I think two are front wheel bearings.
        The larger ones appear to be the inner / outer front wheel bearings. The smaller ones appear to be the rear wheel bearings. Seals appear to be for the front wheels. The inner front seal has an extended lip to receive the end of the CV axle.
        Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
        In memory of Dean Allen - V8 Festiva 1955-2010
          I think "A18" would be the front, as I think the rears were lower numerically. "A4 and A1," I'm guessing from bad recollection.
          Go to Rockauto and check part numbers for front and rear bearings and you may hit paydirt.
          Okay, I checked, since it was easy (though you should doublecheck!).
          A18 is a front bearing. A4 and A1 are the rear bearings. "National" uses those part numbers, but there are the same cross references for the SKF brand.
          I AIN'T THAT SENILE...YET!!
          And...20205 is a front seal.
          Now you do the rest.
          Karl
            6202zz is the trans input shaft bearing, goes in the flywheel,
            A18 frt wheel bearings, GBR11 frt wheel brg, (Set 11 in Timken).
            20205 Frt seal inner.
            The gears appear to be tranny gears and I am lost there.
            66839 appears to be outer wheel seal, best guess. (can't tell size for sure).
            5728225 cup & 5728226 cone appear to be rear wheel bearing.
            Best guess on all
            it runs so sweet
            91 L 5spd
