Aspire Auto Transmission.
  • Aspire Auto Transmission.
    I have a 95 aspire and sometimes when I put it in drive, it takes a little bit to get going. 20 seconds or so to act normal. It only does it after it has not been driven for a day or two. After it starts going everything is great until it sits again. Are there any check valves that are suppose to keep the TC pressurized? Could one of those not be doing it job. Anybody got a diagram of an auto and the parts that can be replaced when the pan is dropped.
    Thanks,
    Eric
    Blue 1989 Festiva L 1.3 carb 160K+, Aspire 5spd, Aspire swap, Tach, Added A/C, Intermittent wipers.
    Aqua 1991 Festiva L 1.3 FI 200K+, 5spd, Aspire swap, tach, Intermittent wipers.
    Green 1995 Aspire 1.3 FI 95K (RIP Saved my 18yo sons life)
    You might be right on your thoughts with what's wrong with the car... but I have to ask... Did you make sure the fluid level was good in the transmission? When was the last time the fluid was changed? I wonder if the the transmission filter is clogged...
    Just my .02!
    www.cardomain.com/id/jermnc77
    Madness Committee Member & Contact Person
    www.festivamadness.com
    Festiva Madness
    Snoopy's
    4621 Atlantic Ave
    Raleigh, NC 27604
      Fluid level looks good. It looks clean also. I am dropping the pan to change the filter soon and I am looking for ideas on what to look for. Hopefully a new filter will fix the problem.
