Spark plugs rusted in........
  • Spark plugs rusted in........
    Hello guys
    Festiva was getting major tune up and when removing the spark plugs there where old and rusted badly
    He was able to remove 2 of them but the other where rusted so bad that there wernet any tread on them....
    He tried and tried to remove them..... never could
    so how do I get those plugs out to replace them.... its runs good but has 2 old plugs from forever and 2 new ones
    Soak em with PB Blast or some equivalent.
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      the socket wont even go on them....
      there is just a chunk of rust noting to hook socket on
        Had a similar problem with another car and PB Blast did the trick but you may have to soak it several times. It will break loose eventually.
        '93 Festiva GL / "HOT ROD"
        '02 F-150 Supercrew
        '02 Excursion 4x4
        '98 Jeep Cherokee Classic Limited
          there is nothing to hook the wrench or socket on it...... its round rusted
            I'd still soak it in PB Blaster, several times over the course of a day. Go out the next day and try to get a pair of pliers on the plug. Might come out then.
              There is a type of easy out that is tapered on the inside that is meant for removing hard to do studs, it threads on counterclock wise and after soaking the plugs quite possibly overnite they will come out. You can get them at supply houses that supply tool and die products or taps etc.
                not sure where to find it other then I saw one at walmart.....it is a socket with a bunch of pins in it that press out of the way when you stick it on whatever.....might work for you....also saw something similar item at home depot....in the tool section.
                  yes....those too....I forgot...you will have to snap the tops off the plugs though.
                    snap end out of plugs?
                    if I cant remove it 100% I am screwed... need new head....
                    always something like this happens to me
                    they removed 2 and the 2 other cant even get the wrench on
                      that one with the pins will not work, the one I mentioned is like a deep socket that starts to thread on counter clock wise and when it gets really tight the spark plug will come out. Then chase the threads in the plug socket with a slightly magnetized thread chaser to avoid getting metal particles inside the motor or put some grease on it so it will catch the metal pieces, small as they are.
                        I did one for a friend of mine once. I broke the top of the spark plug off and then welded a bolt to the plug. was not as far recessed but talk to a welding shop in your area. should not charge too much
                        Beauty is in the eye of the beer holder.
                          Snap On twist deep socket
                          You can get them any size you need. I think Craftsman makes something similar and cheaper.
                          No need to break the plug. But do soak them with PBB for a couple days before you try to remove them.
                          Oscar
                            You really should try PB Blaster, when I was changing the head gasket on my Mustang a couple years ago, a head bolt snapped with less than half an inch sticking out of the block. We soaked it in PB Blaster, and while my dad was waiting for it to soak and working on something else, my friend pulled it out BY HAND. That stuff really works.
                              Just read all the small print on the side of the crazy can and you believe in the stuff. It tells you how to test it against other lubes..... Extractors may be your only way.
                              -Greg
                              Redneck Engineer
                              FOTY - '09
