I have a problem that it is running lean
  • I have a problem that it is running lean
    Hello
    I have a Kia pride 1.3 be engine efi. I have a problem that it is running lean. It has a new o2 sensor used maybe 1000 miles, new spark plugs used the same mileage. A cold air intake, Exhaust mufflers removed only the middle resonator. I have a problem of running lean. I checked the spark plugs and they are white. I think it is running lean. Normal air/fuel ratio should be brownish color. What shall I do to enrich the air/fuel ratio a bit?
    Thank you
    :festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
    Originally posted by lancerevo View Post
    Hello
    has a new o2 sensor
    is it a bosch or ebay brand sensor?
    is the vehicle an obd2?
      It is an ebay o2 sensor. I think that is the problem. What do you think? How could I find out if it's an obd2?
        obd2 was required beginning in 96. Some cars got it early though. I just wondered. You can research to find if it is obd2. The engine compartment labels, door sticker, look for the plug (although that is not certain), there is a list of obd2 vehicles on the internet somewhere...
        Try to read the sensor output
