Okay so first start with a cold engine is great, fires up drive around no problems... If I drive around till the engine heats up and then shut the car off when I start it up again it will not want to run... just touching the throttle kills the engine. Oh and the engine light comes on. Now if I let it sit till everything is cool again, like overnight it is perfectely fine to go in the morning... Help please...
I Should Know This but....
my guess......ignition module in the distributor.-Greg
Redneck Engineer
FOTY - '09
X2
You can take the module out and get it tested for free at some parts stores. If it needs replacing call around for prices because they vary a lot even though it's all the same mannufacturer. Some people buy used distributors and get it cheaper that way. I tried and got a junk yard distributor with a bad module. I put some info on the modules in a webpage at http://www.ag384bn.bravehost.com/Cars.htmOriginal owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
AFTER
