Well,finally got it in and running.When it first starts up runs decent.Once it warms up , you push gas and it wants to stall and revs high.My buddy seems to think CAT is clogged.? Second,shifter linkage,pictured below......Pin in it is loose.Was there a bushing in it or something ? Real sloppy and you have to play with it to get it in gear.It is real loose(where the pin goes in).Not sure if it is the pin or the hole it is in is worn ? Fix ?Also,timing light work good or is there an easier way to time it ?
Pass CV boot was torn , so ,I got new ones(boots).How the heck does the end come off.Book says there is a retainer ring.We cleaned all rease out and we cannot see one.Should I just get a QUICK BOOT ? Pics below..
Book pic...
Misc pics of car so far...
Book pic...
