check engine light
  • check engine light
    ok ever since i got the car the check engine light comes on very brief and shuts off, but some times right after it turns off the car will start to sputter if during driving when idling it will rev up and then just go back to normal. i don't know what it would be maybe tps? or a leak in my intake tube? but not sure what do you guys think?
    need to have the check engine code read.....not sure how you do it on a Festy though.
      well since it is obd1 it is hard to find a place that does it and is cheap and just like a egt on the driver side fight below the wiper motor its a big square one
        you can do it without a machine.....just not sure how on a Festy...someone will pipe up.
          As Monsoon would say, "Search is your friend"
          Get the code and look here for what it means...
          Hope this helps!
          My Fleet:
            see....I knew it was grounding something but I did not want to guess....or search myself....lol. Nice of you doylerl
              Not a problem. I help when I can, and get help when I am can't...
              My Fleet:
                yeah you guys really helped me
                  And what was the problem ?
                    I hope that wasn't a sarcastic response.......
                      it was
                        What part was not of help? Could you not get a code with that method or what? I will help as much as I can, as long as I know what you have tried and haven't tried.
                        My Fleet:
                          Freaking Admins!!
                          Seriously, grover, which part do you need help with?
                          1988 L - 232K miles Batstiva
                          1989 L - 247K miles Slick
                            it was
                            so.....because you did not want to take the advice to get the code read and then you say it is hard to find someone to do it and I tell you it can be done and then doylerl finds the thread that tells you very simply how you can do it.
                            That wasn't enough help for you. So you decide it is better to be sarcastic about it instead of taking the time to try. What do you want......I know....give me your address and I will come over this weekend and do it myself....seeing that you can not.
                              Why waste your time GD? Itd be unappreciated at best.
                              - Unknown
                              - Quentin Crisp
                              - Bumper Sticker
