My 88 L is blowing headlight bulbs?
light problems
make sure you have the correct Amperage fuses too...
-Aspire brake swap COMPLETE!
When installing the headlight bulbs do not touch the bulb glass.
Use a clean cloth to set the bulbs in the holders, before inserting them into the headlight itself.
Give us some details as to how many times this has happened.
Under what conditions.
How long do the bulbs last before "blowing"?
Both bulbs or only one.
etc
etc
etc
The more we know about the problem the better we can help.Last edited by Pu241; 12-14-2009, 11:42 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Poverty produces creativity
