Guys:
I am trying to add some transmission fluid to a '94 Aspire with a manual transmission. I removed the speedometer cable from the top of the transmission by loosening the bolt and pulling the cable upward. Easy.
I was surprised by how little fluid I was able to add, like less than 1/4 of a quart. The guys at the Crappy Lube told me I was leaking transmission fluid, so I expected to be able to add at least a quart.
My question is, do I need to remove something else in order to add fluid? When I pulled out the cable, I could see a keyed collar inside the hole. The cable has a matched, keyed component that fits into this collar. Do I need to somehow remove the "collar" from inside the tranny in order to add fluid? If so, how??
Incidentally, the transmission is making horrendous sounds when in gear. Hoping that adding fluid helps, but I'm not holding my breath.
Has anyone had luck using a heavier gear oil in a manual transmission Aspire to extend the life of a failing transmission? The Dextron/Mercon stuff is so thin...
Thanks for any help you can provide.
Andy
Andy
