no headlghts
  • no headlghts
    headlights went out on wife on her way home last night,ckd wiring and bulbs,they are good,relay on right side makes buzzing noise when switch isturned on,any help out there
    Check for 12 V at the red wire on the headlight relay.
    If you have 12 V then unplug the headlight relay and apply 12v to the white wire. If the headlights come on then its the relay. If they dont come on it could be the headlight switch. I dont recall the relays making a buzzing sound.
      Also check the main fuseable links are OK, happened to me and one was badly corroded
      "all I ask is the chance to prove that money won't make me happy":simon:
