hey everyone, finally got my festiva on the road as of 4 days ago =P been having the same problem ive always had and cant seem to remedy it. i can drive it 5 minutes.. to 1 hour.. when I turn it off it wont run for a good half hour to an hour making quick stops a pain. itll just crank and never turn over. but if i leave it and come back itll fire up right away.
stuff fixed thus far
new:
gas tank
fuel filter
fuel pump
wires/plugs
all 4 struts
outer tie rod ends
lower control arms
front/rear brakes & e-cable
battery
battery connector pieces
wiring for rear hatch
lots of wiring in engine bay
windshield
4 aluminum rims, 4 new all season tires
timing belt, installed myself, then timed at a shop
ect..
cleaned the dist and sanded all the contacts clean
replaced the igniton coil and module
rewired the cooling fan
unclogged the air filter box
oil change, topped up trans fluid
changed over to cartridge fuses
some of the things ive been thinking i need to do
new valve cover gasket
timing belt covers
new battery cables
clean the contacts on the grounds
engine coolant change
any ideas as to why it wont start after driving it? i noticed the pulley on the alternator is tight, but i also noticed 1 of the 3 screws holding on the pulley is snapped off? maybe a culprit, most of this stuff on the car atm is all original parts and its sitting at 456k, so it could be anything
new:
gas tank
fuel filter
fuel pump
wires/plugs
all 4 struts
outer tie rod ends
lower control arms
battery
windshield
ect..
timing belt covers
new battery cables
