what could be the situation here? I looked at the break fluid reservoir and it was empty so I filled it with dot 3 brake fluid. Now it seems the brakes are working better but still the pedal goes far down until it starts really braking the car. Im wondering if I need new break pads or just to adjust the pedal or what.? Any Ideas?
Brakes not very good....pedal has a lot of play....
First question is where did the brake fluid go?
My guess is you have a leak somewhere.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yeah, could be leaking master cylinder, could be the wheel cylinders, or the brake lines themselves. Those would be the first areas to check.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
also take a look at the proportioning valve.
Put clean cardboard, paper, whatever under the wheels and some under the car in the neighborhood of the Master cylinder and proportioning valve.
Then press the pedal a few time every 15-30 min for a few hours, should see something by morning, depending on how big it is.
Of course with the snow we are assuming you have a garage.'93 Blue 5spd 230K(down for clutch and overall maintanence)
^ A well-lit and heated garage, stocked with tools.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
