Hi everyone,
I took my ignition rotor off the other day to check something ('88 festy, carb), and in my rush I forgot what position the rotor was in when I removed it. Does it only go on the shaft one way, or can it be installed in different positions?
I'm replacing the ignition module (again), so after it is installed, and if it doesn't start, can I then assume the rotor is positioned incorrectly, and try another position?
I should know this, but I don't!
Thanks and have a good holiday.
