Brake fluid leaking btw master cylinder and booster?
  • Brake fluid leaking btw master cylinder and booster?
    Is there a seal you can replace in there or do i need a whole need MC? It goes empty after about 3 days of driving.
    Need to get this replaced by sunday.
    IIRC, there is a gasket between the MC and the Brake Booster. If that is where your leak is coming from, then it's got to be that gasket. Been a while since I've done one(fortunately). Not that bad a job.
    1988 L - 232K miles Batstiva
    1989 L - 247K miles Slick
      Your fluid is blowing by the rear cup that is internal to the master cylinder.
      You need either another cylinder or a clean-up and refurb of the one you have. Rebuilt ones aren't cheap.
      Be sure you bench bleed the new/refurbed cylinder before you put it on the car.
        yeah mine is doing that too, freaking reman is expensive too.
        Current cars:
          Here's the Rock Auto prices: http://www.rockauto.com/catalog/rafr...arcode=1128147
          Even the most expensive one is cheaper than bodywork or hospital bills IMO.
            I just bought a MC today! Bought it at O'reilly's. Reman $44.99+ $15 core charge.
            New $79.99.
            Dan
              Soooo... If you're aspire swapped... advisable to switch over to an Aspire MC?
              My MC is leaking a tiny bit and my breaks have like 2 inches of travel before anything is applied.
                x2 i got the aspire swap, better to switch?
                  New $79.99.
                  advanced auto is cheaper....really starting to like that place now that i got the festy
                    Advanced here is so,so...Autozone sucks.
                    Oreillys always seems to have Festiva parts in stock! And a kicker...
                    they will deliver the part you need (if not in stock) within 1-2 hrs.. with no money down. Just go get when it comes in. Also, the one by my house is run by a Festiva owner!ccasion5:
                    Dan
