I don't know what to do :(
  • I don't know what to do :(
    sooo on christmas my check engine light came on...idk what's wrong with it...i put oil in it and it's still acting up. Yesterday it wouldn't start until my step dad jump started it then it worked great...i tried it this morning and it wouldn't start. he jumped started it again and it worked perfectly. i tried it again an hour ago and it wouldn't start. i don't know what to do...my check engine light is still on.
    Amazing Amanda
    Check the battery terminals if you haven't already. Have the battery tested, bad battery? Alternator must be ok or it wouldn't run when jumper was removed. Hope this helps.
    1991 Festiva EFI
    Papabug
      Good time to check/replace the battery. I would take the O2 sensor out and clean it (with something that won't kill it). See if that helps clear that CEL.
      Oscar
        so if i get a new battery will the check engine light go off??
        Amazing Amanda
          Well, maybe for a little while It should go off once you disconnect the battery for several minutes but, if the problem is still there, the CEL will come back. Clean the O2 sensor, disconnect the [new] battery, and cross your fingers
          Oscar
            When you change the battery it will clear the codes the light will go off. If there is a reason (O2 sensor) as mentioned the light will reappear. If it doesn't that's a bonus..
            1991 Festiva EFI
            Papabug
              how do u disconnect a battery?? i don't really know anything about fixing cars!
              Amazing Amanda
                Amanda take your car to auto repair shop, normallly they will check a charging system for free. They can also check the battery. Battery's that are weak fail when its really cold outside.
                93 GL modyfied!!!
                :fish:
                  alright...i'll have to do that! yea it's starting to get really cold now...this is the first time i've had my festiva in the winter so I didn't really know what to expect.
                  Amazing Amanda
                    i work in a shop and lately with the bad weather people have been coming in left and right with bad batteries and alternators its crazy lol
                    92 civic sedan VTAK
                    91 festiva small and slow
                      yea i bet...i was scared that I was guna have to get a new car! my mom was talking about getting me a new truck for my graduation present!...she thinks my festiva is a piece of junk! I've rather have my festiva
                      Amazing Amanda
                        I concur with everyone else here. It's you battery. If it was the alt. the car would not run once the jumper cables were disconnected. And batteries can die quickly. Take it to any McParts place, and they can check your charging system for free. But I'm betting it's going to be your battery.
                        You didn't fall on it and break it, did you?
                        1988 L - 232K miles Batstiva
                        1989 L - 247K miles Slick
                          take it out and take it to an autozone or somewhere like that and have them test it for free. You don't have and friends that live around you that know at least a little about cars and can help you?
                            Originally posted by aglatfe1 View Post
                            i'd rather push a festiva than drive a honda!
                            i don't think so!...u r totally wrong!!...
                              I would!!!
                              93 GL modyfied!!!
                              :fish:
