PLEASE HELP GUAGE CLUSTER PROBLEM
  • PLEASE HELP GUAGE CLUSTER PROBLEM
    took my speedometer out tonight to replace some blown bulbs in the temp section. now the dash will not light up and i can't get the freakin speedometer cable back in the cluster. fuses are all good--jeremie
    sounds like you missed a plug to plug in the back for the lights
    and as for the speedo cable, try disconnecting it from the transaxle first to give you slack to pull through and an easier connection to the speedometer
      Yeah what mechanicaldj. Once you disconnect the speedo cable from the transaxle you'll be able to rotate the inner drive cable easily so you can line it up and it should slip right into place.
      1993 Festiva GL, 67,783miles, 1.3L, FI, Auto, A/C, Radio
      1990 Festiva L, 193,067miles, 1.3L, FI, 5 Speed, No A/C, No Radio
      1999 ZX2, 180,436miles, Zetec, 5 Speed
      1999 F-350, Duallie, Diesel
        and you will have slack in the cable, so you can see when you install the cable outside of the dashboard area.
