Brakes leaking...yet another problem, any ideas?
    Nicely done, zanzer, thanks.
      Just noticed my brake fluid was very low also. I'll have to check this also. Thanks Zanzer, nice write up!
      My Musica! Click me!
        No problem guys Anything to help out a fellow owner
        Hopefully it will save you some time and money. I replaced everything but the reservoir and grommets before I figured this little trick out.
        It got to a point where I was like "fill it up with brake fluid and check the gas" :scratch:
        WWZD
        Zulu Ministries
          Zan, you are the man!:p
          Dan
