Ok, I've got a 93 fuel injected Festiva L 1.3L and had a bad oil leak that burned up my alternator so it had to be fixed. It was a bad cam seal so I replaced it and the crank seal, timing belt, valve cover gasket, plenum gasket, water lines, plugs, wires, cap, rotor, fuel filter, and alternator.
Now it will start and idle normal but as soon as I touch the throttle it dies.
Any help will be greatly appreciated!
ops:
