Hmm...
  • Hmm...
    So my Festy went from sounding like a low rpm motorcycle to a lawnmower...Its definitely taking alot more gas to accelerate her now.
    The exhaust and engine is shaking like hell...The engine also slows up a bit...Is she dieing on me?! :cry:
    Sounds like you lost a cylinder or two. To test if you are running on all cylinders or to find which cylinder isn't working, pull off one spark plug wire at a time. If the engine slows down when you pull a wire, that cylinder is working. If you pull a wire off and the sound/speed of the engine doesn't change, that cylinder isn't working. It's a good place to start.
      Good call seems the spark was just loose...Runs as she always has!
