will the festy manifold bolt on to the mx3 head
mx3 head
I think the mx3 is a b6-me and has unique intake and exhaust manifolds. But the entire engine will bolt in and run. Ask Ricky (manxbuggy) he has done the swap.Neil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
91 L B6-me f25mr-soon to be ???
86 b2000- pisses of HOA-sold
1997 k1500 suburban- kid hauler/GAS hog
The MX3 manifold ports are oval shaped to accomodate the 2 valves per cylinder and the Festy's are round. I cobbled up a carbed intake to fit on the MX3 engine on our original race car. It worked good enough to be competitive, even won a race with it. If I remember correctly, only the 2 outer most studs on the MX3 head will match the Festy intake stud holes. The rest of the holes (and manifold) had to be built up with weld and re-drilled. I then had to do some major port grinding to both the intake and the head to get the ports to match up reasonably well. It's not a pretty looking job either. I also had to make my own custom made intake gasket.
I used the MX3 exhaust manifold and didn't attempt to re-work the Festy exhaust to fit.
The Australian Ford Laser uses the B6-ME in their early nineties cars. Since the time I fabricated my intake, I have been able to buy a carbed intake from an Australian Laser and it fits perfectly on the MX3 engine.You gonna race that thing?
