trying to remove my door hinges. and can not get to the 5th bolt on the top hinge. any suggestions?
door hinge removal
Sorry for the delay I am at work. However, I havent tried my theories so if they dont work please let me know or someone else who has done this before will surely chime in.
First off have you remove the front fender or removed some of the bolts so you can manuever the fender carefully to gain access? There is a bolt right next to the top hinge and then if you pop your hood there should be more that you can remove. I would try using a wrench when it come to getting to the bolt you want due to limited sapce. Or a offset wrench would probably be better. Good luck I hope this helps.Man should eat when he can for Man does not know when his last meal will be.
