Carbed to Fuel injected.....??
  • Carbed to Fuel injected.....??
    Don't know if this is the right place or not, but I just recently bought 2 festivas, one is carb'd and the other is fuel injected.....the FI one doesn't have a title and I was wondering how hard it would be to change the carbed one over to FI?
    Has anyone on here done this? How hard is it? I'm assuming I would have to change wiring harnesses, gas tank....what else?
    00' GT mustang
    Built MPH motor
    89 Festevil
    just swap the dashboards, so the carbed vin is on the fi car.
    Jim DeAngelis
    kittens give Morbo gas!!
      Also remove the door tags (stickers). Save the one that matches the dash your using. The vin # is also stamped on the firewall, no easy way to switch this.
      Swap the dash, remove the door tags and don't worry about it.
      I used the dash out of a carbed car in my FI car. I had to swap the harness in the dashes. The 88 and 90 dash plugs were different.
      matt
        Thanks guys.....I was also wonderin how hard it would be to take the FI stuff off the one car and take the carb off the other and make the carb'd car a FI car.....how hard would that be? Is it even worth it?
        00' GT mustang
        Built MPH motor
        89 Festevil
