After the cam gear broke I cranked to see if I was getting oil to the top and certainly was.
Cam locked up in head
Originally posted by grey View PostWould you prefer I used the word "term" or "classification" instead of "rule"?
As long as the original poster understands, then I dont think it makes any difference which word is used.
Valve to piston contact is possible."FLTG4LIFE" @FINALLEVEL , "PBH"
I'm not certain that even if you shaved the head to the point you'd get contact that you'd have a running engine as the compression ratio could well be too high for pump gas.
You may well be correct on other engines, but not on these.'93 Blue 5spd 230K(down for clutch and overall maintanence)
So I have oil up to the head I should be good just putting the head I have on. Non interefence means the valves WONT hit the piston when a timing belt breaks! I don't understand why people are saying it can!! Don't take this the wrong way but if you don't have any car knowledge don't keep making un needed posts in my thread. I was simply wondering what people have seen and should it be ok to put on just a new head without any worries. Once again, NON-INTERFERENCE MEANS THE VALVES WILL NOT HIT THE PISTON. Ok sorry Im done being irritated now.
Thanks! Some rep points will be put in the appropriate places for people who know certain definitions.
Originally posted by Sandm849 View PostSo I have oil up to the head I should be good just putting the head I have on. Non interefence means the valves WONT hit the piston when a timing belt breaks! I don't understand why people are saying it can!! Don't take this the wrong way but if you don't have any car knowledge don't keep making un needed posts in my thread. I was simply wondering what people have seen and should it be ok to put on just a new head without any worries. Once again, NON-INTERFERENCE MEANS THE VALVES WILL NOT HIT THE PISTON. Ok sorry Im done being irritated now."FLTG4LIFE" @FINALLEVEL , "PBH"
Yea I tend to get a little aggrivated! Thanks for your input. Now if only I knew remembered how to add rep points!!
lol...just click the little symbol next to the dot on the left that shows if a person is on or not."FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by Sandm849 View PostYea I tend to get a little aggrivated! Thanks for your input. Now if only I knew remembered how to add rep points!!
Good luck on getting your car fixed up!
Thanks!
A lot of people recieved some rep. Pu241, Geneva, 25horse and others all got some rep pts!
This car is an 88 so it is carb. Somebody just mentioned that I might have to put an online fuel pump if I use an efi head. Can't I just take the block off plate out and install the fuel pump??
left message in other thread but I believe that some of the heads are solid without block off plates....newer efi's"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by GenevaDirt View Postleft message in other thread but I believe that some of the heads are solid without block off plates....newer efi's
So Sandm849 yes you should be able to take the block off plate, off an EFI engine and install the mechanical fuel pump, there should be the lobe on the EFI camshaft already to drive the mechanical fuel pump
