Originally posted by Pu241
I do not advocate trans fluid or Kero/diesel. Neither have sufficient lubricity to maintain protection of parts in high pressure locations (rod bearings, cam lobes) and actually contain less detergent than modern engine oil. In fact, kero and diesel contain no detergents. They simply act as a solvent and dispersion agent, removing lubricant from important places.
Products like Seafoam do not disperse lube, although they will reduce its viscosity. They act as detergents vs solvents, when used in the appropriate quantities.
