need info about fuel pump
  • need info about fuel pump
    I have a 91 festiva and need info about the fuel pump. The pump in the tank is going out, can Iput an electric in line pump instead of dropping my tank? If so what would be the psi needed?
    Welcome!
    You don't drop your tank to swap out the fuel pump.
    There is an access port under the back seat.
    Fold the seat forward, pop the plastic faseners holding down the carpet.
    You'll then see a plate with a couple of wires going ounder it.
    Undo the hold down bolts and remove.
    Under the plate is the top of the fuel tank and the fuel pump/sender assembly.
    This is held in place by 8 philips head screws.
    Might need to hit them with PB-Blaster so you don't strip them out (makes for a long day).
    This is the short version a detailed version can be provided.
    Give some though to adding your location to your profile as someone in your area may be in the area and can help you with this.
    Go to User CP (top of the Page in the blue bar)
    Control Panel(left side of screen)
    Edit Profile-scroll to bottom of page to location.
      If the one in the tank is going out, it needs to be replaced. Adding an in-line will make it pull fuel thru a dead pump and it will self destruct. Pumps are easy enough to get to and can be bought on ebay for $30 or so.
      Oh yea and WELCOME to the site.
      -Greg
      Redneck Engineer
      FOTY - '09
        hey thanks for the help .you sure saved me from alot of unessary work so once again thanks for the quick reply
          i did mine right before winter hit. its an easy fix
          92 civic sedan VTAK
          91 festiva small and slow
            Yea very easy to do. The hard part is trying to not spil. Any gas in your interior!
            The new keeper of Uncle Fester!! 88 5-speed, efi, now with ac!
            1988 LX ~sold~
            1992 Blue GL auto, ac ~sold~
            2008 Nissan altima 3.5sl loaded <lease returned>
            1996 Nissan maxima <sold>
            2002 ford f350 crew cab short bed diesel
            Just remember, it could be worse, you could have a fork in your eye!!
