Ive had my festy for about 6 months now and its a 90 L, for some reason heat doesnt come out of the central vent, only from the top defrost and the floor heat will come out of which to me isnt normal but the other festy i sold which was an 89 LX i picked up with my other one has the same issue. I also checked to see if the levers were moving by the heater box and theyre all moving perfectly on both cars, so is this a coincidence or a design flaw?
Also if u leave the car idling on a day thats below 30 deg it takes roughly a half an hour to get the car warmed up but nearly 45 min to get the fan to kick on, i also tried to stick a piece of cardboard in front of the radiator, used radiator flush thinking maybe something is clogged in my cooling system somewhere as well as new thermostat, hoses and flushed the rad, heater core, and engine with garden hose that has some decent pressure behind it so in theory its clean in there. The owner said he flushed the system about every 5 years since it was new, as well as replaced the thermostat and hoses along with the coolant with all Ford parts.
Any ideas would be greatly appreciated.
