Ok, Ok, Ok,
How can it be the module when i'm not getting spark TO THE MODULE? No power before it gets to the module. Power comes up thru the coil leads, to coil, then across the coil wire to distributor, where the module is located. Following that path, i'm getting 5.7 volts from the wire leads to the coil, no fire coming out of coil, BEFORE it gets to the distributor, where the module is located. It has to be something else, following the path that way. As in posts above, I have 3 coils, all checking in spec., and NOT GETTING FIRE OUT OF ANY OF THE COILS.
(sorry, but I was asked about the module like 6 times)
I cant see how it could be the module, if i'm not getting fire from the coil and not getting enough voltage to the coil. By process of elimination and following the power path, if power stops before the distributor, where module is located, then it will not be the module, as no spark is reaching the distributor/module right?
If someone can explain how it can be the module, when its not getting spark to the module, then I will be amazed and humbled! I welcome all ideas, but in my mind, it cant be the module, unless of course, there is something about the module that prevents the coil from firing and not getting enough voltage to coil, and that doesnt make sense to me.
