For some reason the dash heater vents in my 91 festiva only blow cold air. the defrost and floor settings blow nice hot air but as soon as i switch it to the dash it just blows out whatever temperature the air is outside. what could be causing this? it's done it ever since i got the car, i've just been running floor and de frost settings but now i'm kinda wondering what's going on with it.
Dash vents mystery
Dash vents mystery
A nice car is like another mans woman, you can look but do not touch!
91 civic h/b built and boosted a6/z6 and wagovan real time 4wd conversion
68 plymouth barracuda fast back 4spd (summer car)
91 L (RIP)
65 plymouth sport fury 2dr convertible 440 (SOLD)
63 plymouth valiant 2 dr sedan (SOLD)
93 dodge dakota 5.2L 4x4 (SOLD)
86 Ranger 2.9L 4x4 with 4inch lift (SOLD)
AND I WISH I STILL HAD THEM ALL!Tags: None
hahaha ok so no easy fix?A nice car is like another mans woman, you can look but do not touch!
91 L (RIP)
Confuscious say: "Wise man search for answers, before asking question..."
need any more?Jim DeAngelis
Oh that would be WWAAAAYYYY too easy :lol:Originally posted by FB71 View PostConfuscious say: "Wise man search for answers, before asking question..."
This is strictly my opinion. I don't like to run additional accessories thru my cigarette lighter. Reason being, if you have a wiring problem, you could have a melting wireloom nightmare. I recommend adding a fused socket from the battery. Lower risk of problems.Originally posted by brickdog2000 View PostJust buy a saspce heater that plugs into your cigarette lighter.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
those space heaters do not work anyway.....if the car has working heat then the defrost and floor vents are MORE then sufficient to heat the car."FLTG4LIFE" @FINALLEVEL , "PBH"
Yep, I went thru this wild goose chase recently when I bought my first FestivaOriginally posted by Bazzy16 View PostFor some reason the dash heater vents in my 91 festiva only blow cold air. the defrost and floor settings blow nice hot air but as soon as i switch it to the dash it just blows out whatever temperature the air is outside. what could be causing this? it's done it ever since i got the car, i've just been running floor and de frost settings but now i'm kinda wondering what's going on with it.
('90) with 49K miles, yellow that I bought from the estate of a friend. He was 93 years old and owned the car since new. Got it from his daughter for $400.
Then a friend from Georgia told me that the dash vents don't put out any heat.
DUH!
I was working on the haet because the heat sensor for the gauge went bad on my way over to Raleigh for the Festiva rally in October.
So far I have replaced the thermostat, the radiator fan relay and I have the gauge relay but can't get to threlay for it, need a long #10 socket.
Good luck with your future adventures in the Festiva world.
Dave
