I need advice on manual.
  • I need advice on manual.
    There are two kinds of manuals for me to choose. One kind is just for the model of my car (trio wf 2000year) but it's more expensive at 130+ dollars. The other kind is for the prior model such as wb and cheaper at 50+ dollars. Are there many differences between wf and prior models? If I buy the 50-dollar one, will it able to work on my car?
    I think you need to stick to the manual for your car....not sure about Australia but they changed the car here. First is was Festiva 88-93....then it was Aspire 94-95 and then Aspire OBDII 96 on.
    I would check Ebay....the book sounds extremely high unless you are talking the Factory repair manual.
      Adam I'm in NZ and I have a cheaper manual...Gregory's No.605, its a cheaper version but it does not go into detail but just covers the most basic, its helpful and enough for someone like me who wouldn't pull a gear box apart, but if you want something more specialised then I guess you need to pay more, that manual has been enough for me to keep my Festiva going for 8 years.
      Always change the oil at 10,000km (max) and always replace the oil filter at the same time
      "all I ask is the chance to prove that money won't make me happy":simon:
        Thanks
