Speedo is jumpy
  • Speedo is jumpy
    When im driving, the MPH needle in the cluster jumps around and shakes. Its not a big deal, it only moves 2-3 mph or so, I was just wonderin what it could be?
    Tyler
    91 Festiva, 5spd, B8 swapped, now for paint and suspension
    Lube the cable with some grease, and see if that helps.
    '90 LX
      hanging up.....needs lubed most likely
        graphite not grease.if you you use grease its your fault because i told you so
