I finally got around to drop the engine in last week and I got everything hooked up.
I was able to get it started and the timing seems to be right but the front end was leaking oil and it seemed to be coming from the front main crank seal.
The seal that came in my kit was wrong, it was for the cam shaft and the original looked fine so I re-used it.
But once I had the leak I was sorry I did.
So I tore the front end down and replace checked the seal, it was loose.
I already had a new seal so I replaced it and re-assembled the engine and fired it up.
It ran great for about 3 minutes and then the it started to leak again.
Does anyone know if this is a normal problem?
Is it possible that I have the seal in backwards? Once it was installed the flat side was facing out and the U channel with the spring was facing in.
Is it possible that is wasn't seated right?
Any help I can get would be appreciated.
Thanks
Thanks
