heat
  • heat
    is it just my car or do all festivas heat take forever to warm up mine takes about 8 min good driving to even start to get warm
    1989 Ford Ranger 177 2.9
    2001 hyundai accent 1.6 DOHC
    I believe it's just the way they are......my Festiva, (93 GL ATX), does the same thing. Boy my Neon and Stratus's are blowing warm air within 2 blocks of driving.
    Don
      yeah i think they're like it as well.
      even in the mild temperatures over here it takes a few miles to get up to temp. which is a bummer as i only takes me 12 mins to get to work. so by the time it's warmed up i'm at work.
      KIA Pride 1996 1.3i LX 5dr 5speed.
        Every one I've ever driven is like that. I used to drive 60 miles one way when I was going to school. On days when the temp was well below 0°F, they never do get very warm, even if you have the front end covered up.
          People here have had some improvement with a piece of cardboard in fron of the radiator
          I will NOT drive a minivan
            Mine has always done the same, and partially blocking the radiator has worked well for me too
            4-spd 1989 Festiva - carburated baby!
              My radiator is fully blocked. I also block the area to the left of the radiator where the A/C condenser goes. It helps quite a bit.
