Aspire running out of gas
  • Aspire running out of gas
    I nearly ran out of gas today... the engine started losing power intermittantly depending on my like, position. I jammed the clutch in and coasted off the freeway and into a gas station.
    Engine never stalled, but I was able to put 9.5 gallons in it. How much damage could I have done by letting it get this low?
    I should also mention that it did act fine after i put gas in it, but i've always read that letting it get too low can damage the fuel pump
    it just takes a little life off of your pump and puts more of the crap off the bottom of your tank into your sock
      I've ran out of gas at least 5 times due to a partially defective fuel gauge.
      Haven't seen any side effects yet though, although it is very hard on the fuel pump.
      Regards,
      Tim
      White '89L auto - Sold!
      Silver '06 Rav4, 95k!
        excellent. My car has enough wrong with it to begin with so I don't need to be replacin the fuel pump
        Thank you all!
