Hello All,
we own a 1990 L Plus, the chassie has 265k and the engine is around 110k it is a stick trans. To this point the car has ran like a champ.
The other night it was cold i mean freeze your balljoints off,the battery went dead,bought a new one and put it in,starts good just like old times.the car is running and i'm picking up the tools,i dropped an open end wrench on the positive post the other end touched the coil mount and the car died,it refired right up.
I got in the car and started to drive, about a half block later the engine starts to clatter like a loose rocker arm,drove it up to the house shut it off,thought about the problem and went back out and started the engine and hey no noise,it comes and goes,now it's full time. Bought a valve cover gasket and going to check the rockers,it just seams a little to coinsidental.
I checked injecter resistance 13.8 13.7 13.8 and 14.0 it has new plugs, wires, cap, any ideas out there.
I am a junior member and did a search first but if i missed something just let me know.
Thanks
Thanks
