Some kind of Elec. problem
  • Some kind of Elec. problem
    I'm thinking I have a elec. problem hope someone can help me.
    First my driver side shoulder restraint doesn't work from time to time, I have swapped out the box under the seat and that's not it.
    The weird thing is when I turn the heater fan motor to (2) sometimes the restraint will work.
    Any idea's that I should try? I have a parts car so I can swap parts out.
    The restraint works fine when it is working but I think I'm losing power to it or I have a short somewhere.
    Mike.
    Did you check the switch and make sure it was ok?
    Did someone mess with the wiring before you got it?
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      ^i'm w/ Monsoon on this one, clean the door switch contacts and ground screws, they have a tendancy to corrode and loose contact.
        How do I get to them? are you talking about the one in the latch?
